Inleiding
The solid state drive stores data and works as a type of flash memory. Use this guide to remove the drive from your laptop if you would like to replace or upgrade it.
Wat je nodig hebt
Flip your device so that the bottom panel is facing up.
Remove the eleven 5mm Torx T5 screws from the back panel.
Remove the two 3mm Phillips #1 screws holding the battery to the laptop chassis.
Disconnect the battery from the IO board by holding the connector by the sides and gently pulling the connector out.
Remove the one 2mm Phillips #1 screw holding the hard drive to the laptop.
8 andere personen hebben deze handleiding voltooid.
3 opmerkingen
How to transfer the windows os to the newly install Crucial ssd?
how to transfer the windows OS to the newly install ssd?
