Ga door naar hoofdinhoud
Lenovo Yoga 700-11ISK Power Port Replacement
Wat je nodig hebt
  1. Lenovo Yoga 700-11ISK Power Port Replacement, Back Panel: stap 1, afbeelding 1 van 2 Lenovo Yoga 700-11ISK Power Port Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Flip your device so that the bottom panel is facing up.
    • Remove the eleven 5mm Torx T5 screws from the back panel.
  2. Lenovo Yoga 700-11ISK Power Port Replacement: stap 2, afbeelding 1 van 1
    • Use a spudger to unclip clips on the front and near the USB ports on each side
    • Lift the back panel off
  3. Lenovo Yoga 700-11ISK Power Port Replacement, Battery: stap 3, afbeelding 1 van 1
    • Remove the two 3mm Phillips #1 screws holding the battery to the laptop chassis.
    • Disconnect the battery from the IO board by holding the connector by the sides and gently pulling the connector out.
  4. Lenovo Yoga 700-11ISK Power Port Replacement: stap 4, afbeelding 1 van 1
    • Carefully remove the battery from the laptop.
    • Make sure that all wires still connected to the laptop are out of the way and not pulled out with the battery.
  5. Lenovo Yoga 700-11ISK Power Port Replacement, Power Port: stap 5, afbeelding 1 van 2 Lenovo Yoga 700-11ISK Power Port Replacement, Power Port: stap 5, afbeelding 2 van 2
    • Remove the following screws holding both the right LCD hinge and the power port to the laptop:
    • Four 5mm Phillips #1 screws.
    • One 3mm Phillips #1 screw.
    • Gently pull the hinge up and away from the laptop.
  6. Lenovo Yoga 700-11ISK Power Port Replacement: stap 6, afbeelding 1 van 3 Lenovo Yoga 700-11ISK Power Port Replacement: stap 6, afbeelding 2 van 3 Lenovo Yoga 700-11ISK Power Port Replacement: stap 6, afbeelding 3 van 3
    • Carefully slide bundle cable connector out from its connector on the motherboard.
    • Pull the ends of the black connector containing the wires to avoid damage to the wires.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Emma Morley
378 Reputatie
2 handleidingen geschreven
Cal Poly, Team 15-6, Livingston Fall 2016 Lid van Cal Poly, Team 15-6, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G6
4 Leden
7 handleidingen geschreven
2 opmerkingen
Hey
I own lenovo yoga 700 14 inch, it has a motherboard 5b20k41654. For some reason two of mother board ics burnt out
I have got the number of one IC but failed to find the number/code of other. (the IC I am looking for resides near left side of ram slot)
Please let me know if someone can help me finding the right IC or Schematic of yoga 700 motherboard
I'll be very great full
Thanks
muhammad bilal - Antwoord
If you’re replacing the power port where is the part? How do I find the power port to replace? Which part is it?
atom_burke - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 29
Altijd: 5,524
