Ga door naar hoofdinhoud
Lenovo Yoga 3 Pro USB Ports Replacement
Wat je nodig hebt
  1. Lenovo Yoga 3 Pro USB Ports Replacement, Battery: stap 1, afbeelding 1 van 1
    • Before opening your laptop, make sure it is powered off.
    • Remove the ten 3.3 mm screws from the base cover using a T5 Torx screwdriver.
  2. Lenovo Yoga 3 Pro USB Ports Replacement: stap 2, afbeelding 1 van 1
    • Slide the plastic opening tool between the base cover and the frame to pry open the computer.
    • Slowly go around the entire perimeter of the computer until all edges are loose.
    • Make sure the plastic opening tool doesn't go too far into the device.
  3. Lenovo Yoga 3 Pro USB Ports Replacement: stap 3, afbeelding 1 van 1
    • Remove the panel and place it in a safe location.
  4. Lenovo Yoga 3 Pro USB Ports Replacement: stap 4, afbeelding 1 van 1
    • Remove the six 3.5 mm screws surrounding the battery using a Phillips 00 screwdriver.
    Hi
    I have a Lenovo Yoga 3 pro - 1370
    I take off the SSD without remove the battery. Is this a problem?
    TKS
    Stanley
    Stanleyslaw Castro - Antwoord
  5. Lenovo Yoga 3 Pro USB Ports Replacement: stap 5, afbeelding 1 van 1
    • Using either tweezers or your fingers, disconnect the black battery cable by pinching either side of the connector and pulling towards the battery.
  6. Lenovo Yoga 3 Pro USB Ports Replacement: stap 6, afbeelding 1 van 1
    • Carefully lift and remove the battery.
    If you have the right tools, this is really straightforward to do. Took me about 10 minutes. The instructions are very accurate.
    Kevin Lawless - Antwoord
    Regarding the battery connector, the male plug is attached to the battery wiring (you will know what I mean when you look at it) and the female socket is attached to the logic board. There are small ridges on either side of the plug that can be grasped with fingernails to gently tease the plug out of the socket.
    Ron Westfall - Antwoord
  7. Lenovo Yoga 3 Pro USB Ports Replacement, Speakers: stap 7, afbeelding 1 van 1
    • Remove the four 4 mm screws using the Phillips 00 screwdriver.
  8. Lenovo Yoga 3 Pro USB Ports Replacement: stap 8, afbeelding 1 van 2 Lenovo Yoga 3 Pro USB Ports Replacement: stap 8, afbeelding 2 van 2
    • Using the plastic opening tool, flip open tab as shown.
  9. Lenovo Yoga 3 Pro USB Ports Replacement: stap 9, afbeelding 1 van 3 Lenovo Yoga 3 Pro USB Ports Replacement: stap 9, afbeelding 2 van 3 Lenovo Yoga 3 Pro USB Ports Replacement: stap 9, afbeelding 3 van 3
    • Remove the adhesive tape.
    • Flip open the ribbon connecting tab.
    • Carefully lift the ribbon connector from its adhesive.
  10. Lenovo Yoga 3 Pro USB Ports Replacement: stap 10, afbeelding 1 van 2 Lenovo Yoga 3 Pro USB Ports Replacement: stap 10, afbeelding 2 van 2
    • Remove the speaker and set it on the side.
    • Use the plastic opening tool to remove the cables.
    • Be careful of other cables.
  11. Lenovo Yoga 3 Pro USB Ports Replacement: stap 11, afbeelding 1 van 2 Lenovo Yoga 3 Pro USB Ports Replacement: stap 11, afbeelding 2 van 2
    • Removing the other speaker by unwinding cables.
    • Lift both speakers carefully.
  12. Lenovo Yoga 3 Pro USB Ports Replacement, USB Ports: stap 12, afbeelding 1 van 2 Lenovo Yoga 3 Pro USB Ports Replacement, USB Ports: stap 12, afbeelding 2 van 2
    • Use the plastic opening tool to flip open the tab on each ribbon connector as shown.
    • Ribbon connectors can be fragile, so be gentle when disconnecting them.
  13. Lenovo Yoga 3 Pro USB Ports Replacement: stap 13, afbeelding 1 van 1
    • Remove the three indicated 3.5 mm screws using the Philips 00 screwdriver.
  14. Lenovo Yoga 3 Pro USB Ports Replacement: stap 14, afbeelding 1 van 1
    • Remove the USB assembly.
    • If this is the side that was not working, then follow the steps backwards from here to put it back together.
  15. Lenovo Yoga 3 Pro USB Ports Replacement: stap 15, afbeelding 1 van 1
    • On the other side of the laptop, remove the two 3.5 mm screws using the Philips 00 screwdriver.
  16. Lenovo Yoga 3 Pro USB Ports Replacement: stap 16, afbeelding 1 van 1
    • Remove the two 2.5 mm screws using the Philips 00 screwdriver.
  17. Lenovo Yoga 3 Pro USB Ports Replacement: stap 17, afbeelding 1 van 1
    • Use the plastic opening tool to lift the metal cable holders.
    • Exercise caution. Cable holders will break if lifted too far.
  18. Lenovo Yoga 3 Pro USB Ports Replacement: stap 18, afbeelding 1 van 1
    • Lift the USB port up and use the plastic opening tool to loop the wires around the USB port.
  19. Lenovo Yoga 3 Pro USB Ports Replacement: stap 19, afbeelding 1 van 1
    • Remove the USB assembly using the plastic opening tool.
  20. Lenovo Yoga 3 Pro USB Ports Replacement: stap 20, afbeelding 1 van 1
    • Disconnect the WiFi card from the USB assembly.
    • Be careful with the connectors on the WiFi card as they are fragile.
  21. Lenovo Yoga 3 Pro USB Ports Replacement: stap 21, afbeelding 1 van 1
    • Pull the second USB hub off.
    • Be careful when pulling out the cable.
    I need to replace this part. Why don't you sell it here? Love the instructions, but need the spare part.
    Leon Simons - Antwoord
Conclusie
10 andere personen hebben deze handleiding voltooid.
Caroline Seifert
538 Reputatie
2 handleidingen geschreven
Cal Poly, Team 12-17, Maness Fall 2015 Lid van Cal Poly, Team 12-17, Maness Fall 2015
CPSU-MANESS-F15S12G17
4 Leden
15 handleidingen geschreven
4 opmerkingen
Repaired customers Yoga 3 that had NO working USB ports whatsoever in less than an hour - after cleaning & replacing (no parts needed)
All USB ports were fully functional once again...
Great job & thank you for the help :)
admin - Antwoord
This guide helped me quite a bit today. I really appreciate you providing it.
Jon Tucich - Antwoord
Can you please help with information on where to get the DC input USB port part. My USB port is broken and unable to find it
Dheeraj - Antwoord
None of the 3 USB ports were powering on.
Windows seemed happy and no drivers and bios update helped …
I took apart following this guide, cleaned all ports and PCBs with IPA and a toothbrush and now it’s all working again!
Thank you
ori elyada - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 45
Altijd: 13,232
