Inleiding
Over time, the USB ports collect dust, dirt, and can become damaged for a multitude of reasons all of which ultimately lead to connectivity issues. This guide will help you remove the USB ports in order to clean or replace them.
Wat je nodig hebt
Remove the ten 3.3 mm screws from the base cover using a T5 Torx screwdriver.
Remove the six 3.5 mm screws surrounding the battery using a Phillips 00 screwdriver.
Hi
I have a Lenovo Yoga 3 pro - 1370
I take off the SSD without remove the battery. Is this a problem?
TKS
Stanley
Carefully lift and remove the battery.
If you have the right tools, this is really straightforward to do. Took me about 10 minutes. The instructions are very accurate.
Regarding the battery connector, the male plug is attached to the battery wiring (you will know what I mean when you look at it) and the female socket is attached to the logic board. There are small ridges on either side of the plug that can be grasped with fingernails to gently tease the plug out of the socket.
Use the plastic opening tool to flip open the tab on each ribbon connector as shown.
Pull the second USB hub off.
I need to replace this part. Why don't you sell it here? Love the instructions, but need the spare part.
10 andere personen hebben deze handleiding voltooid.
4 opmerkingen
This guide helped me quite a bit today. I really appreciate you providing it.
None of the 3 USB ports were powering on.
Windows seemed happy and no drivers and bios update helped …
I took apart following this guide, cleaned all ports and PCBs with IPA and a toothbrush and now it’s all working again!
Thank you
