Ga door naar hoofdinhoud
Lenovo Yoga 3 Pro Speakers Replacement
Wat je nodig hebt
  1. Lenovo Yoga 3 Pro Speakers Replacement, Battery: stap 1, afbeelding 1 van 1
    • Before opening your laptop, make sure it is powered off.
    • Remove the ten 3.3 mm screws from the base cover using a T5 Torx screwdriver.
  2. Lenovo Yoga 3 Pro Speakers Replacement: stap 2, afbeelding 1 van 1
    • Slide the plastic opening tool between the base cover and the frame to pry open the computer.
    • Slowly go around the entire perimeter of the computer until all edges are loose.
    • Make sure the plastic opening tool doesn't go too far into the device.
  3. Lenovo Yoga 3 Pro Speakers Replacement: stap 3, afbeelding 1 van 1
    • Remove the panel and place it in a safe location.
  4. Lenovo Yoga 3 Pro Speakers Replacement: stap 4, afbeelding 1 van 1
    • Remove the six 3.5 mm screws surrounding the battery using a Phillips 00 screwdriver.
  5. Lenovo Yoga 3 Pro Speakers Replacement: stap 5, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Using either tweezers or your fingers, disconnect the black battery cable by pinching either side of the connector and pulling towards the battery.
  6. Lenovo Yoga 3 Pro Speakers Replacement: stap 6, afbeelding 1 van 1
    • Carefully lift and remove the battery.
  7. Lenovo Yoga 3 Pro Speakers Replacement, Speakers: stap 7, afbeelding 1 van 1
    • Remove the four 4 mm screws using the Phillips 00 screwdriver.
  8. Lenovo Yoga 3 Pro Speakers Replacement: stap 8, afbeelding 1 van 2 Lenovo Yoga 3 Pro Speakers Replacement: stap 8, afbeelding 2 van 2
    • Using the plastic opening tool, flip open tab as shown.
  9. Lenovo Yoga 3 Pro Speakers Replacement: stap 9, afbeelding 1 van 3 Lenovo Yoga 3 Pro Speakers Replacement: stap 9, afbeelding 2 van 3 Lenovo Yoga 3 Pro Speakers Replacement: stap 9, afbeelding 3 van 3
    • Remove the adhesive tape.
    • Flip open the ribbon connecting tab.
    • Carefully lift the ribbon connector from its adhesive.
  10. Lenovo Yoga 3 Pro Speakers Replacement: stap 10, afbeelding 1 van 2 Lenovo Yoga 3 Pro Speakers Replacement: stap 10, afbeelding 2 van 2
    • Remove the speaker and set it on the side.
    • Use the plastic opening tool to remove the cables.
    • Be careful of other cables.
  11. Lenovo Yoga 3 Pro Speakers Replacement: stap 11, afbeelding 1 van 2 Lenovo Yoga 3 Pro Speakers Replacement: stap 11, afbeelding 2 van 2
    • Removing the other speaker by unwinding cables.
    • Lift both speakers carefully.
Conclusie
Caroline Seifert
541 Reputatie
2 handleidingen geschreven
Cal Poly, Team 12-17, Maness Fall 2015 Lid van Cal Poly, Team 12-17, Maness Fall 2015
CPSU-MANESS-F15S12G17
4 Leden
15 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 17
Altijd: 2,837
