Inleiding
If your device is overheating or gets hot quickly, it might be time replace the cooling fan.
Wat je nodig hebt
Remove the two 3mm screws using the PH#0 screwdriver head.
Unscrew the three 4mm screws using PH#1 (the larger screws do not come off the are attached to the housing unit of the cooling fan).
Één andere persoon heeft deze handleiding voltooid.
