Ga door naar hoofdinhoud
Lenovo Yoga 3 11 Trackpad Replacement
Wat je nodig hebt
  1. Lenovo Yoga 3 11 Trackpad Replacement, Lower Case: stap 1, afbeelding 1 van 1
    • Remove the eleven 6 mm T5 Torx screws securing the lower case.
    • Gently lift the lower case up and away from the device.
  2. Lenovo Yoga 3 11 Trackpad Replacement, Battery: stap 2, afbeelding 1 van 3 Lenovo Yoga 3 11 Trackpad Replacement, Battery: stap 2, afbeelding 2 van 3 Lenovo Yoga 3 11 Trackpad Replacement, Battery: stap 2, afbeelding 3 van 3
    • Remove the two 3 mm Phillips #00 screws securing the battery.
    • There are arrows on the battery indicating the location of the screws.
  3. Lenovo Yoga 3 11 Trackpad Replacement: stap 3, afbeelding 1 van 1
    • Use a pair of tweezers to gently disconnect the battery connector.
  4. Lenovo Yoga 3 11 Trackpad Replacement: stap 4, afbeelding 1 van 2 Lenovo Yoga 3 11 Trackpad Replacement: stap 4, afbeelding 2 van 2
    • Use a pair of tweezers to gently disconnect the speaker cable.
    • Remove the wires from underneath the battery tabs using the tweezers.
  5. Lenovo Yoga 3 11 Trackpad Replacement: stap 5, afbeelding 1 van 1
    • Carefully remove the battery from the device.
  6. Lenovo Yoga 3 11 Trackpad Replacement, Trackpad: stap 6, afbeelding 1 van 1
    • Remove the four 2 mm Phillips #0 securing the trackpad.
  7. Lenovo Yoga 3 11 Trackpad Replacement: stap 7, afbeelding 1 van 1
    • Use the tweezers to partially remove the tape.
  8. Lenovo Yoga 3 11 Trackpad Replacement: stap 8, afbeelding 1 van 2 Lenovo Yoga 3 11 Trackpad Replacement: stap 8, afbeelding 2 van 2
    • Use a pair of tweezers to disconnect the ZIF connector securing the trackpad ribbon cable. Gently lift up the black tab and the ribbon cable should come free.
  9. Lenovo Yoga 3 11 Trackpad Replacement: stap 9, afbeelding 1 van 2 Lenovo Yoga 3 11 Trackpad Replacement: stap 9, afbeelding 2 van 2
    • Slightly push down with your thumb to pop out the trackpad.
    • The laptop must be slightly open in order for the trackpad to pop out.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Slade Fernandes
532 Reputatie
3 handleidingen geschreven
USF Tampa, Team 2-3, Blackwell Fall 2015 Lid van USF Tampa, Team 2-3, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G3
4 Leden
11 handleidingen geschreven
Één opmerking
Very brief, great illustrations. Now, I need to try it.
M T Martinez - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 13
Altijd: 2,830
