Ga door naar hoofdinhoud
Lenovo Yoga 3 11 Speaker Replacement
Wat je nodig hebt
  1. Lenovo Yoga 3 11 Speaker Replacement, Lower Case: stap 1, afbeelding 1 van 1
    • Remove the eleven 6 mm T5 Torx screws securing the lower case.
    • Gently lift the lower case up and away from the device.
  2. Lenovo Yoga 3 11 Speaker Replacement, Battery: stap 2, afbeelding 1 van 3 Lenovo Yoga 3 11 Speaker Replacement, Battery: stap 2, afbeelding 2 van 3 Lenovo Yoga 3 11 Speaker Replacement, Battery: stap 2, afbeelding 3 van 3
    • Remove the two 3 mm Phillips #00 screws securing the battery.
    • There are arrows on the battery indicating the location of the screws.
  3. Lenovo Yoga 3 11 Speaker Replacement: stap 3, afbeelding 1 van 1
    • Use a pair of tweezers to gently disconnect the battery connector.
  4. Lenovo Yoga 3 11 Speaker Replacement: stap 4, afbeelding 1 van 2 Lenovo Yoga 3 11 Speaker Replacement: stap 4, afbeelding 2 van 2
    • Use a pair of tweezers to gently disconnect the speaker cable.
    • Remove the wires from underneath the battery tabs using the tweezers.
  5. Lenovo Yoga 3 11 Speaker Replacement: stap 5, afbeelding 1 van 1
    • Carefully remove the battery from the device.
  6. Lenovo Yoga 3 11 Speaker Replacement, Speaker: stap 6, afbeelding 1 van 2 Lenovo Yoga 3 11 Speaker Replacement, Speaker: stap 6, afbeelding 2 van 2
    • Use a pair of tweezers to peel up one side of each of the 3 pieces of tape that cover the speaker wires.
  7. Lenovo Yoga 3 11 Speaker Replacement: stap 7, afbeelding 1 van 2 Lenovo Yoga 3 11 Speaker Replacement: stap 7, afbeelding 2 van 2
    • Use a pair of tweezers to disconnect the ZIF connector securing the trackpad ribbon cable. Gently lift the black tab up, and the cable should come free.
  8. Lenovo Yoga 3 11 Speaker Replacement: stap 8, afbeelding 1 van 3 Lenovo Yoga 3 11 Speaker Replacement: stap 8, afbeelding 2 van 3 Lenovo Yoga 3 11 Speaker Replacement: stap 8, afbeelding 3 van 3
    • Remove the two 2 mm Phillips #0 screws securing the left speaker.
    • Remove the two 2 mm Phillips #0 screws securing the right speaker.
  9. Lenovo Yoga 3 11 Speaker Replacement: stap 9, afbeelding 1 van 2 Lenovo Yoga 3 11 Speaker Replacement: stap 9, afbeelding 2 van 2
    • Use a pair of tweezers to disconnect the speaker connector.
    • Gently lift the speakers free of the device.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Slade Fernandes
520 Reputatie
3 handleidingen geschreven
USF Tampa, Team 2-3, Blackwell Fall 2015 Lid van USF Tampa, Team 2-3, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G3
4 Leden
11 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 9
Altijd: 1,137
