Ga door naar hoofdinhoud
Lenovo Yoga 3 11 Motherboard Replacement
Wat je nodig hebt
  1. Lenovo Yoga 3 11 Motherboard Replacement, Lower Case: stap 1, afbeelding 1 van 1
    • Remove the eleven 6 mm T5 Torx screws securing the lower case.
    • Gently lift the lower case up and away from the device.
  2. Lenovo Yoga 3 11 Motherboard Replacement, Battery: stap 2, afbeelding 1 van 3 Lenovo Yoga 3 11 Motherboard Replacement, Battery: stap 2, afbeelding 2 van 3 Lenovo Yoga 3 11 Motherboard Replacement, Battery: stap 2, afbeelding 3 van 3
    • Remove the two 3 mm Phillips #00 screws securing the battery.
    • There are arrows on the battery indicating the location of the screws.
  3. Lenovo Yoga 3 11 Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Use a pair of tweezers to gently disconnect the battery connector.
  4. Lenovo Yoga 3 11 Motherboard Replacement: stap 4, afbeelding 1 van 2 Lenovo Yoga 3 11 Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Use a pair of tweezers to gently disconnect the speaker cable.
    • Remove the wires from underneath the battery tabs using the tweezers.
  5. Lenovo Yoga 3 11 Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Carefully remove the battery from the device.
  6. Lenovo Yoga 3 11 Motherboard Replacement, Motherboard: stap 6, afbeelding 1 van 1
    • Use a pair of tweezers to disconnect the motherboard-size of the trackpad ribbon cable. Gently lift up the black tab, and the cable should come free from the ZIF connector.
  7. Lenovo Yoga 3 11 Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Use a pair of tweezers to disconnect the keyboard ribbon cable from the motherboard ZIF connector. Gently lift up the white tab, and the cable should come free.
  8. Lenovo Yoga 3 11 Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Use a pair of tweezers to disconnect the motherboard-side of the SD board ribbon cable. Gently lift up the black tab, and then ribbon cable should come free from the ZIF connector.
  9. Lenovo Yoga 3 11 Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Use the tweezers to unplug the USB port from the motherboard by gently lifting the white connector up from the black motherboard connector.
  10. Lenovo Yoga 3 11 Motherboard Replacement: stap 10, afbeelding 1 van 1
    • Use a plastic opening tool to gently pry up the screen cable from the motherboard.
  11. Lenovo Yoga 3 11 Motherboard Replacement: stap 11, afbeelding 1 van 3 Lenovo Yoga 3 11 Motherboard Replacement: stap 11, afbeelding 2 van 3 Lenovo Yoga 3 11 Motherboard Replacement: stap 11, afbeelding 3 van 3
    • Use a pair of tweezers to disconnect the "I/O Side" of the ribbon cable connecting the audio jack/USB port assembly to the motherboard. Gently lift up the black tab, and the ribbon cable should come free from the ZIF connector.
    • Use a pair of tweezers to disconnect the "MB Side" of the ribbon cable connecting the audio jack/USB port assembly to the motherboard. Gently lift up the black tab, and the ribbon cable should come free from the ZIF connector.
    • Remove the ribbon cable from the device.
  12. Lenovo Yoga 3 11 Motherboard Replacement: stap 12, afbeelding 1 van 3 Lenovo Yoga 3 11 Motherboard Replacement: stap 12, afbeelding 2 van 3 Lenovo Yoga 3 11 Motherboard Replacement: stap 12, afbeelding 3 van 3
    • Remove the two 2 mm Phillips #00 screws securing the wireless card (top) and the SSD (bottom).
    • Use a pair of tweezers to disconnect the black and white antenna cables that are connected to the wireless card.
    • Gently lift the wireless card and SSD up and out of the device.
  13. Lenovo Yoga 3 11 Motherboard Replacement: stap 13, afbeelding 1 van 1
    • Remove the three black 2 mm Phillips #00 screws.
    • Remove the single silver 4 mm Phillips #00 screw.
  14. Lenovo Yoga 3 11 Motherboard Replacement: stap 14, afbeelding 1 van 1
    • Gently lift the motherboard up and out of the device.
Conclusie
Chandler Morris
163 Reputatie
1 Handleiding geschreven
USF Tampa, Team 2-3, Blackwell Fall 2015 Lid van USF Tampa, Team 2-3, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G3
4 Leden
11 handleidingen geschreven
Één opmerking
Not as difficult as I thought. I was surprised that there were no empty RAM locations. Usually on a Notebookk lliek this, there is one RAM location soldered to MB, and one empty slot for upgrade. I worked on an identical Yoga 3 pro that ran 16GB. But aht meant it was soldered at factory to one 16GB RAM setup.
Mick Thielen - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 30
Altijd: 7,082
