Ga door naar hoofdinhoud
Lenovo Yoga 2 Pro Wireless Card Replacement
Wat je nodig hebt
  1. Lenovo Yoga 2 Pro Wireless Card Replacement, Wireless Card: stap 1, afbeelding 1 van 1
    • Please ensure that the laptop is turned off before beginning.
    • Using a T5 Torx screwdriver, remove the eleven 1/4" screws from the back of the laptop.
  2. Lenovo Yoga 2 Pro Wireless Card Replacement: stap 2, afbeelding 1 van 1
    • Gently lift off the back cover.
  3. Lenovo Yoga 2 Pro Wireless Card Replacement: stap 3, afbeelding 1 van 1
    • Locate the wireless module above the battery in the top left corner of the computer.
    • Using a spudger, disconnect the two metal connectors by popping the metal piece up from the wireless module.
  4. Lenovo Yoga 2 Pro Wireless Card Replacement: stap 4, afbeelding 1 van 1
    • Remove the one 1/16” screw using a Phillips #00 screwdriver.
  5. Lenovo Yoga 2 Pro Wireless Card Replacement: stap 5, afbeelding 1 van 2 Lenovo Yoga 2 Pro Wireless Card Replacement: stap 5, afbeelding 2 van 2
    • Slide the wireless module towards the battery and lift out of the laptop.
Conclusie
9 andere personen hebben deze handleiding voltooid.
Thomas Simko
2.531 Reputatie
5 handleidingen geschreven
Cal Poly, Team 12-14, Maness Fall 2015 Lid van Cal Poly, Team 12-14, Maness Fall 2015
CPSU-MANESS-F15S12G14
5 Leden
12 handleidingen geschreven
2 opmerkingen
Be careful, there is a very restrictive Whitelist in the BIOS for potential replacements, unofficial support available via their forums;
(tl;dr - go with Intel AC 7260 - m.2 connection)
https://forums.lenovo.com/t5/Lenovo-Yoga...
Jamie Haustead - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 22
Altijd: 11,282
