Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
This guide will explain how to safely remove the screen from your Lenovo Yoga 2 13". It will provide a list of the tools needed as well as the easiest way to remove the screen without damaging it.
Wat je nodig hebt
Using an opening pick, remove one small black rectangle piece on two corners to locate screws.
Carefully remove one 4.762 mm screw from each corner using a Phillips head screwdriver.
11 andere personen hebben deze handleiding voltooid.
3 opmerkingen
Hey Nichelle, do you have any recommended vendors for both the screen and the digitizer? Thanks!
