Ga door naar hoofdinhoud
Lenovo Yoga 2 13" Battery Replacement
Wat je nodig hebt
  1. Lenovo Yoga 2 13" Battery Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Be sure to power off and unplug your device before you begin your repair.
    • With a T5 Torx screwdriver, remove eleven 6.35 mm screws from the back of the laptop.
  2. Lenovo Yoga 2 13" Battery Replacement: stap 2, afbeelding 1 van 1
    • Carefully separate back panel from the laptop.
  3. Lenovo Yoga 2 13" Battery Replacement, Battery: stap 3, afbeelding 1 van 1
    • Locate the battery of the laptop.
  4. Lenovo Yoga 2 13" Battery Replacement: stap 4, afbeelding 1 van 1
    • To remove the battery, use a Phillips head screwdriver to unscrew three 3.175 mm screws. One will be in the center of the battery (covered by a Lenovo sticker) and the other two are in the corners.
  5. Lenovo Yoga 2 13" Battery Replacement: stap 5, afbeelding 1 van 1
    • Disconnect the battery from the laptop by pulling the power connector towards the battery.
    • Pull parallel to the battery, not straight up.
  6. Lenovo Yoga 2 13" Battery Replacement: stap 6, afbeelding 1 van 1
    • Once all wires are unattached to the rest of the computer, remove the battery from the laptop and replace.
Conclusie
12 andere personen hebben deze handleiding voltooid.
Nichelle
1.550 Reputatie
5 handleidingen geschreven
Marist, Team 1-2, Laflen Spring 2015 Lid van Marist, Team 1-2, Laflen Spring 2015
MARS-LAFLEN-S15S1G2
3 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 64
Altijd: 31,654
