Ga door naar hoofdinhoud
Lenovo Yoga 2 11" Battery Replacement
Wat je nodig hebt
  1. Lenovo Yoga 2 11" Battery Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • With a T5 Torx screwdriver, remove ten 6.35 mm screws from the back of the laptop.
  2. Lenovo Yoga 2 11" Battery Replacement: stap 2, afbeelding 1 van 1
    • Carefully separate back panel from laptop.
  3. Lenovo Yoga 2 11" Battery Replacement, Battery: stap 3, afbeelding 1 van 1
    • Once you have completed the prerequisite guide, locate the battery of the laptop. Remember to disconnect the battery.
  4. Lenovo Yoga 2 11" Battery Replacement: stap 4, afbeelding 1 van 1
    • Using a #00 Philips Precision Screwdriver, remove the seven 3.175mm screws that hold the battery in place (six on the outside, one in the middle).
  5. Lenovo Yoga 2 11" Battery Replacement: stap 5, afbeelding 1 van 2 Lenovo Yoga 2 11" Battery Replacement: stap 5, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • There will be a clip that connects the battery to the rest of the laptop. Unclasp this clip by inserting tweezers into the connection to completely free the battery.
  6. Lenovo Yoga 2 11" Battery Replacement: stap 6, afbeelding 1 van 1
    • Once all of the wires are detached, carefully remove the battery and replace.
Conclusie
12 andere personen hebben deze handleiding voltooid.
Abbey Hickmann
197 Reputatie
1 Handleiding geschreven
Cal Poly, Team 4-3, Maness Fall 2015 Lid van Cal Poly, Team 4-3, Maness Fall 2015
CPSU-MANESS-F15S4G3
4 Leden
5 handleidingen geschreven
4 opmerkingen
how do I remove unathorized battery error?
Manuel Durugas - Antwoord
POOR INSTRUCTIONS
You have failed to mention that the battery cable is attached by a clip that requires opening.
Terrible.
You just took pictures of unscrewing. Not Useful.
barguybrady - Antwoord
Is it possible to use the computer without the battery? I.e. remove the battery and use the laptop with the power cable only.
Lasse E - Antwoord
The clip?😬how do you remove ?I tried a twizzer,didnt work ,and there a video ?
Estella - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 42
Altijd: 26,588
