Ga door naar hoofdinhoud
Lenovo Yoga 2 11" Back Panel Replacement
Wat je nodig hebt
  1. Lenovo Yoga 2 11" Back Panel Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • With a T5 Torx screwdriver, remove ten 6.35 mm screws from the back of the laptop.
  2. Lenovo Yoga 2 11" Back Panel Replacement: stap 2, afbeelding 1 van 1
    • Carefully separate back panel from laptop.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Peyton Leeson
939 Reputatie
4 handleidingen geschreven
Cal Poly, Team 4-3, Maness Fall 2015 Lid van Cal Poly, Team 4-3, Maness Fall 2015
CPSU-MANESS-F15S4G3
4 Leden
5 handleidingen geschreven
3 opmerkingen
Thanks for this manual.
Would you have the chance to add a photo of the machine without the cover on? My idea is to be able to see what is easily accessible in order to answer some other users' questions such as this one: Could I replace the hard drive with an SSD
dauffret - Antwoord
I believe the "hex screwdriver" is not the correct tool required...I believe it's the Torx screwdriver that would be the correct tool.
David Briggman - Antwoord
Not sure if the description has been updated since the 07/30/17 comment but the required tool is a T5 Torx screwdriver that is mentioned in the ‘Tools’ section…and they are not very common!
Ken Swanston - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 9
Altijd: 4,804
