Inleiding
If your Lenovo Yoga 2 11" 20428 keyboard is not working (keys are getting stuck, keys aren't producing the correct symbols, etc.), use this guide to replace the keyboard.
Before using this guide, make sure your device is powered off and not connected to a power source.
Wat je nodig hebt
Flip the computer over so the bottom is facing up.
Remove the ten 6mm screws with a T5 Torx security screwdriver.
Use the Phillips #000 screwdriver to remove the six 3.3 mm screws around the perimeter of the battery.
Use the Phillips #000 screwdriver to remove the single 6.75 mm screw from the center of the battery.
Use the Phillips #000 screwdriver to remove the four 3.3 mm screws securing the hard drive to the panel.
Use the Phillips #000 screwdriver to remove the two 3.3 mm screws.
Using your finger nail or a thin pry tool, unlock and remove the three cables.
Lift the two pieces of tape. Carefully pull the cable connector back to remove it from the motherboard.
Use the Phillips #000 screwdriver to remove the eight 3.8mm screws.
Use the Phillips #000 screwdriver to unscrew and remove the one 3.3 mm screw that secures the daughterboard.
To reassemble your Lenovo Yoga 2 11" (model 20428) keyboard, follow these instructions in reverse order.
