Ga door naar hoofdinhoud
Lenovo Yoga 2 11" 20428 Battery Replacement
Wat je nodig hebt
  1. Lenovo Yoga 2 11" 20428 Battery Replacement, Back Panel: stap 1, afbeelding 1 van 3 Lenovo Yoga 2 11" 20428 Battery Replacement, Back Panel: stap 1, afbeelding 2 van 3 Lenovo Yoga 2 11" 20428 Battery Replacement, Back Panel: stap 1, afbeelding 3 van 3
    • Flip the computer over so the bottom is facing up.
    • Remove the ten 6mm screws with a T5 Torx security screwdriver.
  2. Lenovo Yoga 2 11" 20428 Battery Replacement: stap 2, afbeelding 1 van 1
    • Carefully remove the back panel by gently separating the panel from front to back.
    • Take care not to pull any wires or crack the outer shell.
  3. Lenovo Yoga 2 11" 20428 Battery Replacement, Battery: stap 3, afbeelding 1 van 3 Lenovo Yoga 2 11" 20428 Battery Replacement, Battery: stap 3, afbeelding 2 van 3 Lenovo Yoga 2 11" 20428 Battery Replacement, Battery: stap 3, afbeelding 3 van 3
    • Use the Phillips #000 screwdriver to remove the six 3.3 mm screws around the perimeter of the battery.
    • Use the Phillips #000 screwdriver to remove the single 6.75 mm screw from the center of the battery.
  4. Lenovo Yoga 2 11" 20428 Battery Replacement: stap 4, afbeelding 1 van 1
    • Gently remove the three pieces of tape securing the Bluetooth/Wi-Fi antenna.
  5. Lenovo Yoga 2 11" 20428 Battery Replacement: stap 5, afbeelding 1 van 2 Lenovo Yoga 2 11" 20428 Battery Replacement: stap 5, afbeelding 2 van 2
    • Grip the base of the connector with your fingers or pliers, and gently pull the connector straight back towards you to remove it.
    • If possible, do not to pull the connector out by the wires, as this can damage the connector.
  6. Lenovo Yoga 2 11" 20428 Battery Replacement: stap 6, afbeelding 1 van 2 Lenovo Yoga 2 11" 20428 Battery Replacement: stap 6, afbeelding 2 van 2
    • Carefully remove the battery from the laptop.
    • Take care not to pull out the Bluetooth antenna while removing the battery.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 31
Altijd: 696
