Inleiding
This guide will show how to properly remove and replace the battery component. The safe disconnection of the battery is a key so that you do not shock yourself or any of the other components within the laptop.
Wat je nodig hebt
Flip the computer over so the bottom is facing up.
Remove the ten 6mm screws with a T5 Torx security screwdriver.
Use the Phillips #000 screwdriver to remove the six 3.3 mm screws around the perimeter of the battery.
Use the Phillips #000 screwdriver to remove the single 6.75 mm screw from the center of the battery.
Één andere persoon heeft deze handleiding voltooid.
