Ga door naar hoofdinhoud
Lenovo Yoga 11e Chromebook Keyboard Replacement
Wat je nodig hebt
  1. Lenovo Yoga 11e Chromebook Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • There will be 7 Philips head screws on the bottom which will need to be removed to gain access to the battery
    • NOTE: You may void your warranty completing this replacement
  2. Lenovo Yoga 11e Chromebook Keyboard Replacement: stap 2, afbeelding 1 van 1
    • There are two screws that will need to be removed to access the keyboard.
  3. Lenovo Yoga 11e Chromebook Keyboard Replacement: stap 3, afbeelding 1 van 2 Lenovo Yoga 11e Chromebook Keyboard Replacement: stap 3, afbeelding 2 van 2
    • Next, flip the laptop over and open it up. The keyboard can be easily removed by pushing it back from the front. I suggest using a jimmy tool to slip into the tiny gap to push it back.
    • Look closely at the two images you'll notice a slight gap at the bottom if you did this step correctly
  4. Lenovo Yoga 11e Chromebook Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Pull slightly up from the keyboard but NOT all the way, the ribbon cable is still connected to the motherboard
  5. Lenovo Yoga 11e Chromebook Keyboard Replacement: stap 5, afbeelding 1 van 3 Lenovo Yoga 11e Chromebook Keyboard Replacement: stap 5, afbeelding 2 van 3 Lenovo Yoga 11e Chromebook Keyboard Replacement: stap 5, afbeelding 3 van 3
    • Use a plastic pry tool to lift up the plastic clip holding down the ribbon cable. Be very gentle with it so it doesn't break
Conclusie
Congratulations you’ve successfully removed the keyboard! To reassemble your device, follow these instructions in reverse order.
3 andere personen hebben deze handleiding voltooid.
Corey Meyer
2.268 Reputatie
2 handleidingen geschreven
Kid fixers Lid van Kid fixers
Community
161 Leden
298 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 38
Altijd: 1,870
