Ga door naar hoofdinhoud
Lenovo YOGA 730-15IWL Battery Replacement
Wat je nodig hebt
  1. Lenovo YOGA 730-15IWL Battery Replacement, Remove the base cover screws: stap 1, afbeelding 1 van 1
    • Remove the screws (M2.0 x 7.0 mm, Torx).
  2. Lenovo YOGA 730-15IWL Battery Replacement, Remove the base cover: stap 2, afbeelding 1 van 1
    • Remove the base cover. Consider using a spudger.
  3. Lenovo YOGA 730-15IWL Battery Replacement, Remove the battery: stap 3, afbeelding 1 van 1
    • Unplug the battery connector in the direction shown by arrow
    • Remove the screws (M2.0 x 4.5 mm).
    • Remove the battery pack.
Conclusie
To replace the battery & reassemble your device, follow these instructions in reverse order.
Max Kletskov
40.298 Reputatie
16 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
17.198 handleidingen geschreven
2 opmerkingen
My issue with my Lenovo Yoga 730-15 laptop was not the battery I just successfully replaced. It still does not turn on. The Power button light up for a short time when pressed to power up the laptop. However, it then goes out and the laptop does not startup. Any Ideas?? Thanks
Al Cross - Antwoord
Check thermal paste. May be getting hot and shutting back off.
William Mobley - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 46
Altijd: 1,364
