Ga door naar hoofdinhoud
Lenovo YOGA 730-15IKB Speaker Replacement
Wat je nodig hebt
  1. Lenovo YOGA 730-15IKB Speaker Replacement, Bottom Cover: stap 1, afbeelding 1 van 2 Lenovo YOGA 730-15IKB Speaker Replacement, Bottom Cover: stap 1, afbeelding 2 van 2
    • Turn off the computer and unplug the charger before going any further.
    • Flip the laptop over so you can see the underside.
    • Remove the ten 7mm T5 Torx screws.
  2. Lenovo YOGA 730-15IKB Speaker Replacement: stap 2, afbeelding 1 van 2 Lenovo YOGA 730-15IKB Speaker Replacement: stap 2, afbeelding 2 van 2
    • Pry up the bottom cover with an opening tool.
    • Start at the front edge of the cover and make your way along the sides.
  3. Lenovo YOGA 730-15IKB Speaker Replacement: stap 3, afbeelding 1 van 1
    • Pull the bottom cover up and away from the back hinges.
  4. Lenovo YOGA 730-15IKB Speaker Replacement, Speaker: stap 4, afbeelding 1 van 3 Lenovo YOGA 730-15IKB Speaker Replacement, Speaker: stap 4, afbeelding 2 van 3 Lenovo YOGA 730-15IKB Speaker Replacement, Speaker: stap 4, afbeelding 3 van 3
    • Disconnect the speaker cable by pulling the wire towards the front of the laptop.
    • You can also use the white tabs on the connector to push the cable free.
  5. Lenovo YOGA 730-15IKB Speaker Replacement: stap 5, afbeelding 1 van 2 Lenovo YOGA 730-15IKB Speaker Replacement: stap 5, afbeelding 2 van 2
    • When the laptop is upside down, the left speaker is located on the right side of the computer.
    • Pull up on the left speaker to remove it from the chassis.
    • Do not fully remove the left speaker at this point. Notice that the left and right speakers are still connected by a wire.
  6. Lenovo YOGA 730-15IKB Speaker Replacement: stap 6, afbeelding 1 van 1
    • Remove the red and black wire near the front of the laptop from underneath the hooks that hold it in place.
  7. Lenovo YOGA 730-15IKB Speaker Replacement: stap 7, afbeelding 1 van 2 Lenovo YOGA 730-15IKB Speaker Replacement: stap 7, afbeelding 2 van 2
Conclusie
Ellis Ruckman
2.545 Reputatie
6 handleidingen geschreven
Cal Poly, Team S1-G6, White Winter 2020 Lid van Cal Poly, Team S1-G6, White Winter 2020
CPSU-WHITE-W20S1G6
3 Leden
27 handleidingen geschreven
Één opmerking
when the stock can arrive ?
prashantdushara - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 24
Altijd: 792
