Inleiding
Follow this guide to replace or remove the left fan in your Lenovo YOGA 730-15IKB. The fans in a laptop draw air over the components which allows them to stay cool and last longer.
If your fans are noisy or create a high-pitched whining noise, they may need to be replaced. You can also try blowing compressed air into the fan to remove any built-up dust that may be slowing it down.
Wat je nodig hebt
Flip the laptop over so you can see the underside.
Remove the ten 7mm T5 Torx screws.
Remove the black and white antenna wires from the groove on the right side of the fan.
Één andere persoon heeft deze handleiding voltooid.
