Inleiding
This guide will walk you through with replacing the fan of your device. You're going to need to sit down and unscrew a lot of screws to access the fan of your device.
Wat je nodig hebt
Flip the device so the back is facing you.
Using the Phillips #0 screwdriver, unscrew the fourteen screws from the device.
Using the Phillips #0 screwdriver, remove the three screws connecting the fan to the device.
Using a pair of blunt tweezers, disconnect the fan from the motherboard.
Remove the fan from the device.
Één opmerking
What kind of fan is that?
I need to know what to order for replacement.
