Ga door naar hoofdinhoud
Lenovo Y50-70 Touch Fan Replacement
Wat je nodig hebt
  1. Lenovo Y50-70 Touch Fan Replacement, Back: stap 1, afbeelding 1 van 2 Lenovo Y50-70 Touch Fan Replacement, Back: stap 1, afbeelding 2 van 2
    • Remove all twelve 6 mm screws from the back of the laptop using a Phillips #1 screwdriver.
    • Apply a lot of pressure to prevent the screws from stripping.
    • Make sure to turn off the computer first!
  2. Lenovo Y50-70 Touch Fan Replacement: stap 2, afbeelding 1 van 2 Lenovo Y50-70 Touch Fan Replacement: stap 2, afbeelding 2 van 2
    • Gently pull the back cover off the laptop. It should come off easily.
  3. Lenovo Y50-70 Touch Fan Replacement, Fan: stap 3, afbeelding 1 van 2 Lenovo Y50-70 Touch Fan Replacement, Fan: stap 3, afbeelding 2 van 2
    • Remove the three 3.5 mm screws from the fan with a Philips #1 screwdriver.
  4. Lenovo Y50-70 Touch Fan Replacement: stap 4, afbeelding 1 van 3 Lenovo Y50-70 Touch Fan Replacement: stap 4, afbeelding 2 van 3 Lenovo Y50-70 Touch Fan Replacement: stap 4, afbeelding 3 van 3
    • Pull the wire tabs up one at a time to separate them from the motherboard.
    • Do not pull too hard on the wire tabs. It may damage the connection between the wires and motherboard.
  5. Lenovo Y50-70 Touch Fan Replacement: stap 5, afbeelding 1 van 3 Lenovo Y50-70 Touch Fan Replacement: stap 5, afbeelding 2 van 3 Lenovo Y50-70 Touch Fan Replacement: stap 5, afbeelding 3 van 3
    • Remove the black and white antenna cables from the wireless card.
    • Do not pull too hard on the antenna cables, as it might damage the connection to the wireless card.
  6. Lenovo Y50-70 Touch Fan Replacement: stap 6, afbeelding 1 van 3 Lenovo Y50-70 Touch Fan Replacement: stap 6, afbeelding 2 van 3 Lenovo Y50-70 Touch Fan Replacement: stap 6, afbeelding 3 van 3
    • Lift up the fan slightly.
    • Gather the antenna cables(black and white) and speaker wires (red, black, blue, and white). Carefully move them away from the fan.
  7. Lenovo Y50-70 Touch Fan Replacement: stap 7, afbeelding 1 van 2 Lenovo Y50-70 Touch Fan Replacement: stap 7, afbeelding 2 van 2
    • Lift the fan off of the laptop.
Conclusie
8 andere personen hebben deze handleiding voltooid.
Vivian
351 Reputatie
1 Handleiding geschreven
Cal Poly, Team 18-1, Maness Winter 2015 Lid van Cal Poly, Team 18-1, Maness Winter 2015
CPSU-MANESS-W15S18G1
5 Leden
15 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 19
Altijd: 9,347
