Ga door naar hoofdinhoud
Lenovo Vibe Z2 Pro Motherboard Replacement
Wat je nodig hebt
  1. Lenovo Vibe Z2 Pro Motherboard Replacement, Lenovo Vibe Z2 Pro Backplate Disassembly: stap 1, afbeelding 1 van 2 Lenovo Vibe Z2 Pro Motherboard Replacement, Lenovo Vibe Z2 Pro Backplate Disassembly: stap 1, afbeelding 2 van 2
    • Remove the 4.9 mm torx head screws located on the camera plate on the back of the phone
  2. Lenovo Vibe Z2 Pro Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Remove the 3.65 mm Torx head screws at the bottom of the phone.
  3. Lenovo Vibe Z2 Pro Motherboard Replacement: stap 3, afbeelding 1 van 2 Lenovo Vibe Z2 Pro Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Remove the SIM card tray by pushing a pin into the hole on the side of the phone.
  4. Lenovo Vibe Z2 Pro Motherboard Replacement: stap 4, afbeelding 1 van 2 Lenovo Vibe Z2 Pro Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Push the Spudger along the gap between the phone and the backplate to separate them.
  5. Lenovo Vibe Z2 Pro Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Carefully pull the backplate away from the phone.
  6. Lenovo Vibe Z2 Pro Motherboard Replacement, Battery: stap 6, afbeelding 1 van 2 Lenovo Vibe Z2 Pro Motherboard Replacement, Battery: stap 6, afbeelding 2 van 2
    • Peel away protective the film using your hands.
  7. Lenovo Vibe Z2 Pro Motherboard Replacement: stap 7, afbeelding 1 van 2 Lenovo Vibe Z2 Pro Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Remove any adhesive strips holding the battery in place gently using a fingernail or spudger.
    • The regular black nylon spudger should be used whenever possible, especially around batteries.
  8. Lenovo Vibe Z2 Pro Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Disconnect the orange battery ribbon cable by gently lifting with a spudger.
  9. Lenovo Vibe Z2 Pro Motherboard Replacement: stap 9, afbeelding 1 van 3 Lenovo Vibe Z2 Pro Motherboard Replacement: stap 9, afbeelding 2 van 3 Lenovo Vibe Z2 Pro Motherboard Replacement: stap 9, afbeelding 3 van 3
    • Insert a fingernail or spudger into either side of the battery and lift upward.
    • Remove the battery from phone.
  10. Lenovo Vibe Z2 Pro Motherboard Replacement, Motherboard: stap 10, afbeelding 1 van 3 Lenovo Vibe Z2 Pro Motherboard Replacement, Motherboard: stap 10, afbeelding 2 van 3 Lenovo Vibe Z2 Pro Motherboard Replacement, Motherboard: stap 10, afbeelding 3 van 3
    • Remove the 3.15mm Phillips Head #000 screws from motherboard.
  11. Lenovo Vibe Z2 Pro Motherboard Replacement: stap 11, afbeelding 1 van 3 Lenovo Vibe Z2 Pro Motherboard Replacement: stap 11, afbeelding 2 van 3 Lenovo Vibe Z2 Pro Motherboard Replacement: stap 11, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Disconnect the two ribbon cables by gently lifting on the black hinges and pulling away with tweezers
  12. Lenovo Vibe Z2 Pro Motherboard Replacement: stap 12, afbeelding 1 van 2 Lenovo Vibe Z2 Pro Motherboard Replacement: stap 12, afbeelding 2 van 2
    • Gently disconnect the rear-camera connector
  13. Lenovo Vibe Z2 Pro Motherboard Replacement: stap 13, afbeelding 1 van 2 Lenovo Vibe Z2 Pro Motherboard Replacement: stap 13, afbeelding 2 van 2
    • Gently remove the front-facing camera by gently lifting on the connector tab.
    • Remove the other connector by gently lifting with a spudger.
  14. Lenovo Vibe Z2 Pro Motherboard Replacement: stap 14, afbeelding 1 van 2 Lenovo Vibe Z2 Pro Motherboard Replacement: stap 14, afbeelding 2 van 2
    • Pry off the plastic brace along the top edge of the phone
  15. Lenovo Vibe Z2 Pro Motherboard Replacement: stap 15, afbeelding 1 van 2 Lenovo Vibe Z2 Pro Motherboard Replacement: stap 15, afbeelding 2 van 2
    • Remove the antenna connected to the bottom piece of the screen plate
  16. Lenovo Vibe Z2 Pro Motherboard Replacement: stap 16, afbeelding 1 van 1
    • Gently lift the motherboard off the frame
    • Pull the camera out from behind the motherboard
  17. Lenovo Vibe Z2 Pro Motherboard Replacement: stap 17, afbeelding 1 van 3 Lenovo Vibe Z2 Pro Motherboard Replacement: stap 17, afbeelding 2 van 3 Lenovo Vibe Z2 Pro Motherboard Replacement: stap 17, afbeelding 3 van 3
    • Using a spudger, disconnect the charging port assembly cable and the screen connection cable.
    • Remove the motherboard completely.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Mitchell Beall
407 Reputatie
1 Handleiding geschreven
USF Tampa, Team 18-3, Blackwell Fall 2016 Lid van USF Tampa, Team 18-3, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G3
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 12
Altijd: 2,049
