Ga door naar hoofdinhoud
Lenovo Vibe Z2 Pro Battery Replacement
Wat je nodig hebt
  1. Lenovo Vibe Z2 Pro Battery Replacement, Lenovo Vibe Z2 Pro Backplate Disassembly: stap 1, afbeelding 1 van 2 Lenovo Vibe Z2 Pro Battery Replacement, Lenovo Vibe Z2 Pro Backplate Disassembly: stap 1, afbeelding 2 van 2
    • Remove the 4.9 mm torx head screws located on the camera plate on the back of the phone
  2. Lenovo Vibe Z2 Pro Battery Replacement: stap 2, afbeelding 1 van 1
    • Remove the 3.65 mm Torx head screws at the bottom of the phone.
  3. Lenovo Vibe Z2 Pro Battery Replacement: stap 3, afbeelding 1 van 2 Lenovo Vibe Z2 Pro Battery Replacement: stap 3, afbeelding 2 van 2
    • Remove the SIM card tray by pushing a pin into the hole on the side of the phone.
  4. Lenovo Vibe Z2 Pro Battery Replacement: stap 4, afbeelding 1 van 2 Lenovo Vibe Z2 Pro Battery Replacement: stap 4, afbeelding 2 van 2
    • Push the Spudger along the gap between the phone and the backplate to separate them.
  5. Lenovo Vibe Z2 Pro Battery Replacement: stap 5, afbeelding 1 van 1
    • Carefully pull the backplate away from the phone.
  6. Lenovo Vibe Z2 Pro Battery Replacement, Battery: stap 6, afbeelding 1 van 2 Lenovo Vibe Z2 Pro Battery Replacement, Battery: stap 6, afbeelding 2 van 2
    • Peel away protective the film using your hands.
  7. Lenovo Vibe Z2 Pro Battery Replacement: stap 7, afbeelding 1 van 2 Lenovo Vibe Z2 Pro Battery Replacement: stap 7, afbeelding 2 van 2
    • Remove any adhesive strips holding the battery in place gently using a fingernail or spudger.
    • The regular black nylon spudger should be used whenever possible, especially around batteries.
  8. Lenovo Vibe Z2 Pro Battery Replacement: stap 8, afbeelding 1 van 1
    • Disconnect the orange battery ribbon cable by gently lifting with a spudger.
  9. Lenovo Vibe Z2 Pro Battery Replacement: stap 9, afbeelding 1 van 3 Lenovo Vibe Z2 Pro Battery Replacement: stap 9, afbeelding 2 van 3 Lenovo Vibe Z2 Pro Battery Replacement: stap 9, afbeelding 3 van 3
    • Insert a fingernail or spudger into either side of the battery and lift upward.
    • Remove the battery from phone.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Bryan Sepulveda
547 Reputatie
3 handleidingen geschreven
USF Tampa, Team 18-3, Blackwell Fall 2016 Lid van USF Tampa, Team 18-3, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G3
4 Leden
12 handleidingen geschreven
2 opmerkingen
Where to buy such battery?
Damir Dominko - Antwoord
wala pa po ba dito s pinas ng bl230?
eduardo santos - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 13
Altijd: 3,362
