Ga door naar hoofdinhoud
Lenovo V15-ADA Hard Disk Drive (HDD) Replacement
Wat je nodig hebt
  1. Lenovo V15-ADA Hard Disk Drive (HDD) Replacement, Back Panel Assembly: stap 1, afbeelding 1 van 2 Lenovo V15-ADA Hard Disk Drive (HDD) Replacement, Back Panel Assembly: stap 1, afbeelding 2 van 2
    • Remove the 10 marked screws using a Phillips #1 screwdriver from the back plate.
    • M2.5 × 7 mm, Phillips-head (6) (RED circles)
    • M2.5 × 4 mm, Phillips-head (4) (ORANGE circles)
  2. Lenovo V15-ADA Hard Disk Drive (HDD) Replacement: stap 2, afbeelding 1 van 2 Lenovo V15-ADA Hard Disk Drive (HDD) Replacement: stap 2, afbeelding 2 van 2
    • After all 10 screws have been removed, insert a spudger between the bottom plate and the housing and slide across.
    • Repeat for all 4 sides until loose.
    • Pop off the back plate and set aside.
  3. Lenovo V15-ADA Hard Disk Drive (HDD) Replacement, Battery: stap 3, afbeelding 1 van 3 Lenovo V15-ADA Hard Disk Drive (HDD) Replacement, Battery: stap 3, afbeelding 2 van 3 Lenovo V15-ADA Hard Disk Drive (HDD) Replacement, Battery: stap 3, afbeelding 3 van 3
    • To start the removal of the battery, disconnect the ribbon cable connecting the battery to the computer.
  4. Lenovo V15-ADA Hard Disk Drive (HDD) Replacement: stap 4, afbeelding 1 van 3 Lenovo V15-ADA Hard Disk Drive (HDD) Replacement: stap 4, afbeelding 2 van 3 Lenovo V15-ADA Hard Disk Drive (HDD) Replacement: stap 4, afbeelding 3 van 3
    • The battery is held in place by 3 screws. Use the Phillips #0 screwdriver to remove the screws that secure the battery.
    • M2 × 6 mm, Phillips-head, nylok-coated (3)
  5. Lenovo V15-ADA Hard Disk Drive (HDD) Replacement: stap 5, afbeelding 1 van 1
    • Remove the battery from the device after completing steps 1 and 2.
  6. Lenovo V15-ADA Hard Disk Drive (HDD) Replacement, Hard-Disk Drive (HDD): stap 6, afbeelding 1 van 1
    • Attach a PH0 head onto the screwdriver and remove screw. (M2 × 6 mm, Phillips-head, nylok-coated)
  7. Lenovo V15-ADA Hard Disk Drive (HDD) Replacement: stap 7, afbeelding 1 van 1
    • Grasp the hard drive and lift up.
  8. Lenovo V15-ADA Hard Disk Drive (HDD) Replacement: stap 8, afbeelding 1 van 1
    • Pull the hard drive from its port.
  9. Lenovo V15-ADA Hard Disk Drive (HDD) Replacement: stap 9, afbeelding 1 van 1
    • The hard drive has been successfully taken out.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jacob Schorr
442 Reputatie
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 41
Altijd: 381
