Ga door naar hoofdinhoud
Lenovo V14-IIL Back Panel Replacement
Wat je nodig hebt
  1. Lenovo V14-IIL Back Panel Replacement, Back Panel: stap 1, afbeelding 1 van 2 Lenovo V14-IIL Back Panel Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Flip your laptop over and place on a flat surface so you can access the screws on the base cover.
    • Remove the six 7 mm screws from the back panel of the laptop using a Phillips #0 screwdriver.
    • Remove the four 4 mm screws from the bottom edge of the laptop using a Phillips #0 screwdriver.
  2. Lenovo V14-IIL Back Panel Replacement: stap 2, afbeelding 1 van 1
    • Use an iFixit opening tool to pry apart the case by sliding it along each side of the laptop.
    • You may need to move the tool to different locations to fully release the back cover.
  3. Lenovo V14-IIL Back Panel Replacement: stap 3, afbeelding 1 van 1
    • Lift away the back panel and set it aside.
Conclusie
Kristen Gismondi
92.224 Reputatie
241 handleidingen geschreven
iFixit Lid van iFixit
Staff
119 Leden
19.521 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 114
