Ga door naar hoofdinhoud
Lenovo V14-ADA Screen Replacement
Wat je nodig hebt
  1. Lenovo V14-ADA Screen Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Turn off the laptop.
    • Disconnect the charging cable from the laptop.
    • Failure to unplug the cable could result in electric shock.
    • Flip the laptop upside down.
  2. Lenovo V14-ADA Screen Replacement: stap 2, afbeelding 1 van 1
    • Remove all ten 5 mm screws from the back panel using a JIS #0 screwdriver.
  3. Lenovo V14-ADA Screen Replacement: stap 3, afbeelding 1 van 2 Lenovo V14-ADA Screen Replacement: stap 3, afbeelding 2 van 2
    • Place the Jimmy in the small crack between the back panel and the keyboard and push down.
    • Repeat this until the panel pops off.
  4. Lenovo V14-ADA Screen Replacement, Battery: stap 4, afbeelding 1 van 2 Lenovo V14-ADA Screen Replacement, Battery: stap 4, afbeelding 2 van 2
    • Remove the four 3 mm screws surrounding the battery using a JIS #0 screwdriver.
    • Slightly pull on the black wire connector to unplug the battery.
    • Lift up the battery to remove it from the laptop.
  5. Lenovo V14-ADA Screen Replacement, Screen: stap 5, afbeelding 1 van 3 Lenovo V14-ADA Screen Replacement, Screen: stap 5, afbeelding 2 van 3 Lenovo V14-ADA Screen Replacement, Screen: stap 5, afbeelding 3 van 3
    • Remove the four 3 mm screws on the hinges on both sides of the back of the laptop.
    • Use the Jimmy to pop the surrounding screen bezel off.
  6. Lenovo V14-ADA Screen Replacement: stap 6, afbeelding 1 van 2 Lenovo V14-ADA Screen Replacement: stap 6, afbeelding 2 van 2
    • Remove the two 3 mm screws at the top two corners of the screen using a JIS #0 screwdriver.
  7. Lenovo V14-ADA Screen Replacement: stap 7, afbeelding 1 van 1
    • Remove the screen from the laptop.
Conclusie
Samaya Roukoz
253 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 4-2, Shaddix Spring 2024 Lid van UMass Dartmouth, Team 4-2, Shaddix Spring 2024
UMASSD-SHADDIX-S24S4G2
5 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 18
Altijd: 172
