Ga door naar hoofdinhoud
Lenovo Touch Y70-70 RAM Replacement
Wat je nodig hebt
  1. Lenovo Touch Y70-70 RAM Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Flip the device so the back is facing you.
    • Using the Phillips #0 screwdriver, unscrew the fourteen screws from the device.
  2. Lenovo Touch Y70-70 RAM Replacement: stap 2, afbeelding 1 van 1
    • Use the blue Opening Tool to pry-open the back cover.
    • Slide it around the perimeter of the PC freeing the back cover.
    • Remove the back cover from the device.
  3. Lenovo Touch Y70-70 RAM Replacement, RAM: stap 3, afbeelding 1 van 2 Lenovo Touch Y70-70 RAM Replacement, RAM: stap 3, afbeelding 2 van 2
    • Use your fingers or two of the blue Opening Tools to lightly pull the tabs away from the RAM to free the first stick.
    • Remove the first stick and and do the same thing to the second RAM stick.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 305
