Ga door naar hoofdinhoud
Lenovo Touch Y70-70 Motherboard Replacement
Wat je nodig hebt
  1. Lenovo Touch Y70-70 Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 1
    • Flip the device so that the back cover is facing you.
    • Using the Phillips #0 screwdriver, remove 14 screws from the back of the device.
  2. Lenovo Touch Y70-70 Motherboard Replacement: stap 2, afbeelding 1 van 3 Lenovo Touch Y70-70 Motherboard Replacement: stap 2, afbeelding 2 van 3 Lenovo Touch Y70-70 Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Using the Phillips #0 screwdriver, remove the three screws holding down the battery.
  3. Lenovo Touch Y70-70 Motherboard Replacement: stap 3, afbeelding 1 van 2 Lenovo Touch Y70-70 Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Using the Phillips #0 screwdriver, remove the metal reinforcement by removing the three screws.
  4. Lenovo Touch Y70-70 Motherboard Replacement: stap 4, afbeelding 1 van 3 Lenovo Touch Y70-70 Motherboard Replacement: stap 4, afbeelding 2 van 3 Lenovo Touch Y70-70 Motherboard Replacement: stap 4, afbeelding 3 van 3
    • Using the Phillips #0 screwdriver, carefully remove the three screws holding down the fan.
    • Detach the cables connecting the fan to the motherboard.
  5. Lenovo Touch Y70-70 Motherboard Replacement: stap 5, afbeelding 1 van 2 Lenovo Touch Y70-70 Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Using the Phillips #0 screwdriver, remove the six screws holding down the cooling unit.
  6. Lenovo Touch Y70-70 Motherboard Replacement: stap 6, afbeelding 1 van 2 Lenovo Touch Y70-70 Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Remove the Ethernet port by unscrewing the two screws holding it down.
  7. Lenovo Touch Y70-70 Motherboard Replacement: stap 7, afbeelding 1 van 2 Lenovo Touch Y70-70 Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Unplug the various cables attached to the motherboard using your fingers carefully.
    • Detach the cables using your fingers.
  8. Lenovo Touch Y70-70 Motherboard Replacement: stap 8, afbeelding 1 van 3 Lenovo Touch Y70-70 Motherboard Replacement: stap 8, afbeelding 2 van 3 Lenovo Touch Y70-70 Motherboard Replacement: stap 8, afbeelding 3 van 3
    • Finally, remove the six screws holding down the motherboard.
    • Remove the motherboard from the laptop.
Conclusie
Mohammed Motorwala
298 Reputatie
2 handleidingen geschreven
IUPUI, Team S2-G5, Harley Fall 2019 Lid van IUPUI, Team S2-G5, Harley Fall 2019
IUPUI-HARLEY-F19S2G5
2 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 13
Altijd: 1,037
