Inleiding
Here it is explained step by step how to replace a M2 SSD of the Lenovo Thinkpad Yoga 370. The specific model code can be found in the sticker with the serial number. In my case it is 20JJ. The materials I have used are:
- New M2 SSD compatible with your model
- Screw like Phillips #1 Screwdriver or the tool provided on iFixit Tool.
I recommend to download also from Lenovo the official guides of your laptop as they have diagrams with the description of the motherboards and its components. In my case:
Wat je nodig hebt
Before remove the back-case of the laptop we have to remove the Pen Pro and the SD card if it is in your model (two boxes in orange on one of the photos).
Circles show the screws to loose. The yellow square indicates where the information about Model is found (20JJ in this case).
Note that after loose the screws we have to remove the case from the bottom part.
The all the screws remain attached to the back-cover as shown in the photos.
Note that the top part of the laptop back cover has several hooks done with plastic (see the photos with blue squares)
Laptop after remove the back-cover. The area in red has the M2.SSD.
The blue arrow shows where is the adhesive part of the M2.SSD that we have to carefully lift off but keeping attached the other part of the cover.
The green arrow shows the screw that we would have to remove to take away the M2.SSD.
First step is remove the screw (this one has to be full removed).
Then we can introduce the new M2.SSD, with a little bit of pressure.
Finally we can fix it with the previously removed screw. Everything should fit well without forcing any component.
To close the back case of the laptop we have to remember the position of the small hooks. Then apply some pressure and screw first the screws on top
After screw again all the 9 screws, we can attach again the Pen Pro and the SD card.
Its done.
