Ga door naar hoofdinhoud
Lenovo Thinkpad X220 HDD Replacement
Wat je nodig hebt
  1. Lenovo Thinkpad X220 HDD Replacement, HDD: stap 1, afbeelding 1 van 1
    • Put the laptop upside down.
  2. Lenovo Thinkpad X220 HDD Replacement: stap 2, afbeelding 1 van 2 Lenovo Thinkpad X220 HDD Replacement: stap 2, afbeelding 2 van 2
    • Unscrew the HDD slot cover.
  3. Lenovo Thinkpad X220 HDD Replacement: stap 3, afbeelding 1 van 2 Lenovo Thinkpad X220 HDD Replacement: stap 3, afbeelding 2 van 2
    • You will arrive to something like this.
    • Pull the black tab popping out to remove the HDD from its tray.
    • The little black tab can be fragile. I recommend you to put tape on it when you have removed the HDD from the bracket to make it tougher.
  4. Lenovo Thinkpad X220 HDD Replacement: stap 4, afbeelding 1 van 2 Lenovo Thinkpad X220 HDD Replacement: stap 4, afbeelding 2 van 2
    • Congratulations! You got the HDD out of the laptop. We can now put the laptop somewhere else and focus on the HDD.
    • On each long side of the HDD, two rubber bands are located. Pull them to remove them and access to the screws.
  5. Lenovo Thinkpad X220 HDD Replacement: stap 5, afbeelding 1 van 1
    • Unscrew the 4 screws located on the two long sides of the drives...
    • ...and push the HDD outside from its retention bracket.
  6. Lenovo Thinkpad X220 HDD Replacement: stap 6, afbeelding 1 van 1
    • You're done! To reassemble, place a new drive in the bracket and follow the steps in the reverse order.
Conclusie
13 andere personen hebben deze handleiding voltooid.
alphaLONE
927 Reputatie
3 handleidingen geschreven
5 opmerkingen
I just hope that a 64 year old crazy cat lady can do this without blowing up the galaxy
Bobbi Johnson - Antwoord
What size drives will fit?
Dan - Antwoord
7mm thick, no more. (I tried with a thicker HyperX 240gb drive but it was too big, wouldn’t fit)
alphaLONE -
eine feine Anleitung. Bravo!
Leitner Josef - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 47
Altijd: 16,176
