Ga door naar hoofdinhoud
Lenovo Thinkpad X201 Tablet Keyboard Replacement
Wat je nodig hebt
  1. Lenovo Thinkpad X201 Tablet Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • First you push the lock button on the back of the computer from lock to unlock.
  2. Lenovo Thinkpad X201 Tablet Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Then you hold it on unlocked and slide the battery pack out.
  3. Lenovo Thinkpad X201 Tablet Keyboard Replacement, Keyboard: stap 3, afbeelding 1 van 3 Lenovo Thinkpad X201 Tablet Keyboard Replacement, Keyboard: stap 3, afbeelding 2 van 3 Lenovo Thinkpad X201 Tablet Keyboard Replacement, Keyboard: stap 3, afbeelding 3 van 3
    • Using a Phillips #00 screwdriver unscrew the four screws in the back of the laptop that have a keyboard symbol next to them.
  4. Lenovo Thinkpad X201 Tablet Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Using your fingers push keyboard forward so it is closer to the screen than it was before
  5. Lenovo Thinkpad X201 Tablet Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Use a flathead screwdriver to gently lift up on the keyboard until it comes off. Make sure you disconnect the ribbon cable from the motherboard before removing the KB completely.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Thomas Donahue
474 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team S5-G7, Peak Spring 2018 Lid van UMass Dartmouth, Team S5-G7, Peak Spring 2018
UMASSD-PEAK-S18S5G7
3 Leden
12 handleidingen geschreven
Één opmerking
Excellent.. thank you.. I just put on my new keyboard. I appreciated seeing your photos just to make sure I didn’t miss anything.
Andy - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 17
Altijd: 2,530
