Ga door naar hoofdinhoud
Lenovo Thinkpad X1 Carbon 4th Gen Wireless LAN Card Replacement
Wat je nodig hebt
  1. Lenovo Thinkpad X1 Carbon 4th Gen Wireless LAN Card Replacement, Bottom Panel: stap 1, afbeelding 1 van 2 Lenovo Thinkpad X1 Carbon 4th Gen Wireless LAN Card Replacement, Bottom Panel: stap 1, afbeelding 2 van 2
    • Unscrew the nine captive screws on the bottom cover of the laptop using a Phillips #1 screwdriver.
    • The screws do not fully come out of the back cover, so there is no need for screw management.
    • There are a few small clips around the edge that you may need to pry at to free them. An opening pick may be helpful for this process.
  2. Lenovo Thinkpad X1 Carbon 4th Gen Wireless LAN Card Replacement: stap 2, afbeelding 1 van 1
    • Lift the back cover up and off of the computer.
  3. Lenovo Thinkpad X1 Carbon 4th Gen Wireless LAN Card Replacement, Wireless LAN Card: stap 3, afbeelding 1 van 2 Lenovo Thinkpad X1 Carbon 4th Gen Wireless LAN Card Replacement, Wireless LAN Card: stap 3, afbeelding 2 van 2
    • Remove the protective film to the left of the fan assembly.
  4. Lenovo Thinkpad X1 Carbon 4th Gen Wireless LAN Card Replacement: stap 4, afbeelding 1 van 3 Lenovo Thinkpad X1 Carbon 4th Gen Wireless LAN Card Replacement: stap 4, afbeelding 2 van 3 Lenovo Thinkpad X1 Carbon 4th Gen Wireless LAN Card Replacement: stap 4, afbeelding 3 van 3
    • Carefully disconnect the gray and black antenna connectors on the green wireless LAN card by lifting under the antennas with an opening tool.
  5. Lenovo Thinkpad X1 Carbon 4th Gen Wireless LAN Card Replacement: stap 5, afbeelding 1 van 1
    • Remove the 2.5 mm screw holding the card in place with a Phillips #1 screwdriver.
  6. Lenovo Thinkpad X1 Carbon 4th Gen Wireless LAN Card Replacement: stap 6, afbeelding 1 van 2 Lenovo Thinkpad X1 Carbon 4th Gen Wireless LAN Card Replacement: stap 6, afbeelding 2 van 2
    • Carefully slide the wireless card out of the slot by pulling it to the right.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Alexander Davis
1.114 Reputatie
7 handleidingen geschreven
Cal Poly, Team S1-G4, White Winter 2020 Lid van Cal Poly, Team S1-G4, White Winter 2020
CPSU-WHITE-W20S1G4
3 Leden
19 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 44
Altijd: 2,113
