Ga door naar hoofdinhoud
Lenovo Thinkpad Tablet 1838 Touch Screen Replacement
Wat je nodig hebt
  1. Lenovo Thinkpad Tablet 1838 Touch Screen Replacement, Touch Screen: stap 1, afbeelding 1 van 1
    • Remove the button with the arrow pointing left.
    • You can do this by putting the spudger underneath the button and pulling up.
  2. Lenovo Thinkpad Tablet 1838 Touch Screen Replacement: stap 2, afbeelding 1 van 1
    • Remove the two 10mm Phillips #00 screws.
  3. Lenovo Thinkpad Tablet 1838 Touch Screen Replacement: stap 3, afbeelding 1 van 1
    • Use an opening tool to pry open and disconnect the screen from the rest of the tablet.
    • Be gentle and work from the bottom of the tablet in counterclockwise direction.
  4. Lenovo Thinkpad Tablet 1838 Touch Screen Replacement: stap 4, afbeelding 1 van 1
    • Open the tablet screen to the left, making sure not to disconnect any of the wires connecting the screen to the tablet.
  5. Lenovo Thinkpad Tablet 1838 Touch Screen Replacement: stap 5, afbeelding 1 van 2 Lenovo Thinkpad Tablet 1838 Touch Screen Replacement: stap 5, afbeelding 2 van 2
    • Disconnect the ribbon connector by pulling up on the white gate.
    • Then just simply pull the wire to the left to disconnect it.
  6. Lenovo Thinkpad Tablet 1838 Touch Screen Replacement: stap 6, afbeelding 1 van 2 Lenovo Thinkpad Tablet 1838 Touch Screen Replacement: stap 6, afbeelding 2 van 2
    • Disconnect the last ribbon connector using your fingernails to grip the ends of the connector and gently pull to the left.
    • There might be some tape over the connector that you will have to remove.
  7. Lenovo Thinkpad Tablet 1838 Touch Screen Replacement: stap 7, afbeelding 1 van 1
    • You have successfully removed the old screen.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 14
Altijd: 754
