1. Remove the button with the arrow pointing left.
    • Remove the button with the arrow pointing left.
    • You can do this by putting your fingernail or a Spudger underneath the button and pulling up.
  2. Remove the two 10mm screws with a Phillips head screwdriver using the #00 bit.
    • Remove the two 10mm screws with a Phillips head screwdriver using the #00 bit.
  3. Use a plastic Spudger to pry open and disconnect the screen from the rest of the tablet.
    • Use a plastic Spudger to pry open and disconnect the screen from the rest of the tablet.
    • Be gentle and work from the bottom of the tablet counterclockwise.
  4. Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  5. Open the tablet screen to the left. Making sure not to disconnect any of the wires connecting the screen and tablet.
    • Open the tablet screen to the left. Making sure not to disconnect any of the wires connecting the screen and tablet.
  6. Disconnect the ribbon connector by pulling up on the white gate. Then just simply pull the wire to the left disconnecting it.
    • Disconnect the ribbon connector by pulling up on the white gate.
    • Then just simply pull the wire to the left disconnecting it.
  7. Disconnect the ribbon connector by opening the white gate. Then just simply pull up on the wire to disconnect it.
    • Disconnect the ribbon connector by opening the white gate.
    • Then just simply pull up on the wire to disconnect it.
  8. Finally Disconnect the last ribbon connector. You can do this by using your fingernails to grip the ends of the connector and simply pulling gently to the left.
    • Finally Disconnect the last ribbon connector.
    • You can do this by using your fingernails to grip the ends of the connector and simply pulling gently to the left.
    • There might be some tape over the connector that you will have to remove.
  9. You have successfully removed the old screen(the part on the left).
    • You have successfully removed the old screen(the part on the left).
Conclusie
Michael Gaskey
337 Reputatie
2 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 1
Afgelopen 30 Dagen: 5
Altijd: 51
