Ga door naar hoofdinhoud
Lenovo Thinkpad Tablet 1838 Button Replacement
Wat je nodig hebt
  1. Lenovo Thinkpad Tablet 1838 Button Replacement, Button: stap 1, afbeelding 1 van 1
    • Remove the button on the front of the tablet that has the arrow pointing to the left .
    • You can do this by putting your fingernail or a Spudger underneath the button and pulling up.
  2. Lenovo Thinkpad Tablet 1838 Button Replacement: stap 2, afbeelding 1 van 1
    • Remove the 2 screws found under the button you just removed with a size #00 Philips Head Screwdriver.
  3. Lenovo Thinkpad Tablet 1838 Button Replacement: stap 3, afbeelding 1 van 1
    • Use a plastic spudger to pry open the screen from the tablet.
    • Work around the perimeter of the tablet going counter-clockwise.
  4. Lenovo Thinkpad Tablet 1838 Button Replacement: stap 4, afbeelding 1 van 1
    • Open the tablet screen to the left. (Like opening a book) Making sure not to disconnect any of the wires connecting the screen and tablet.
  5. Lenovo Thinkpad Tablet 1838 Button Replacement: stap 5, afbeelding 1 van 1
    • To peel back the ribbon connector, first gently open the white gates.
    • You can do this with a plastic Spudger or your fingernail.
  6. Lenovo Thinkpad Tablet 1838 Button Replacement: stap 6, afbeelding 1 van 1
    • Remove the screw that is highlighted.
    • Use a size #00 Philips head screwdriver.
  7. Lenovo Thinkpad Tablet 1838 Button Replacement: stap 7, afbeelding 1 van 1
    • Remove the blue motherboard the screw was attached to.
    • Make sure to remove it carefully, so you do not accidentally damage the surrounding parts.
  8. Lenovo Thinkpad Tablet 1838 Button Replacement: stap 8, afbeelding 1 van 3 Lenovo Thinkpad Tablet 1838 Button Replacement: stap 8, afbeelding 2 van 3 Lenovo Thinkpad Tablet 1838 Button Replacement: stap 8, afbeelding 3 van 3
    • To remove the buttons, you need to push the little black tabs towards each other with either your fingernails or plastic spudger.
    • While the tabs are pushed in the buttons should pop out.
Conclusie
Dylan Coleman
157 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 339
