Ga door naar hoofdinhoud
Lenovo Thinkpad T450s Motherboard Replacement
Wat je nodig hebt
  1. Lenovo Thinkpad T450s Motherboard Replacement, Fan: stap 1, afbeelding 1 van 1
    • Flip the laptop over so that the bottom is facing up.
    • Unlock the battery by sliding the keys outwards. When unlocked, push the battery forwards to remove.
  2. Lenovo Thinkpad T450s Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Unscrew all 3.7 mm Phillips #0 screws from the back of the laptop. Half of them will remain attached to the cover.
    • Lift off the back cover.
  3. Lenovo Thinkpad T450s Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Unscrew the four 5 mm Phillips #0 screws that secure the heatsink.
    • The screws will remain attached.
    • The Fan is attached to the heat sink assembly.
  4. Lenovo Thinkpad T450s Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Use a plastic opening tool or a nylon spudger to push the fan's bundled cable connector free.
    • Remove the fan and heat sink assembly from the motherboard.
  5. Lenovo Thinkpad T450s Motherboard Replacement, Motherboard: stap 5, afbeelding 1 van 1
    • Remove all twelve 3.6 mm Phillips #00 screws.
  6. Lenovo Thinkpad T450s Motherboard Replacement, Remove the Hard Drive: stap 6, afbeelding 1 van 2 Lenovo Thinkpad T450s Motherboard Replacement, Remove the Hard Drive: stap 6, afbeelding 2 van 2
    • Remove the hard drive from the motherboard's by gently pulling it out and up at the same time.
  7. Lenovo Thinkpad T450s Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Pull out the socket that is attached to the left side of the battery case.
  8. Lenovo Thinkpad T450s Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Unplug the cable that attaches the polymer battery to the motherboard by pulling it out carefully.
  9. Lenovo Thinkpad T450s Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Remove the ribbon cable attached to the the battery case carefully by pulling the cable up and out.
  10. Lenovo Thinkpad T450s Motherboard Replacement: stap 10, afbeelding 1 van 1
    • Remove the motherboard from the case. If the motherboard does not come off the case or feels stuck, make sure that you have removed all the cables prior
Conclusie
Sara Karimi Razakani
178 Reputatie
1 Handleiding geschreven
IUPUI, Team 2-3, Harley Spring 2022 Lid van IUPUI, Team 2-3, Harley Spring 2022
IUPUI-HARLEY-S22S2G3
3 Leden
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 43
Altijd: 1,307
