Ga door naar hoofdinhoud
Lenovo Thinkpad T450s Keyboard Replacement
Wat je nodig hebt
  1. Lenovo Thinkpad T450s Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Remove the battery by pulling on the two sliding buttons next to the battery.
  2. Lenovo Thinkpad T450s Keyboard Replacement: stap 2, afbeelding 1 van 2 Lenovo Thinkpad T450s Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Remove the seven 5mm screws on the back cover using the Phillips #0 screwdriver.
  3. Lenovo Thinkpad T450s Keyboard Replacement: stap 3, afbeelding 1 van 1
    • Remove the two rubber stoppers from where the battery previously was.
  4. Lenovo Thinkpad T450s Keyboard Replacement: stap 4, afbeelding 1 van 2 Lenovo Thinkpad T450s Keyboard Replacement: stap 4, afbeelding 2 van 2
    • Flip the laptop, shift the keyboard upwards by applying force to the two indents on the keyboard.
    • Remove the six 5mm screws that are on the keyboard using the Phillips #0 screwdriver.
    • These screws are located above the left ctrl key, S, F, J, semicolon, and up arrow keys.
  5. Lenovo Thinkpad T450s Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Lift the keyboard and flip over exposing the connection to the motherboard.
  6. Lenovo Thinkpad T450s Keyboard Replacement: stap 6, afbeelding 1 van 1
    • Remove the plastic covering and detach touch point and keyboard cable.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Nathan Morgan
469 Reputatie
2 handleidingen geschreven
IUPUI, Team S2-G5, Stella Fall 2019 Lid van IUPUI, Team S2-G5, Stella Fall 2019
IUPUI-STELLA-F19S2G5
3 Leden
Één opmerking
If after replacement your keyboard has some keys clacking, make sure you slid the keyboard all the way back. Even a small amount can make some keys feel weird.
Ivan Veloz - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 31
Afgelopen 30 dagen: 108
Altijd: 6,105
