Ga door naar hoofdinhoud
Lenovo Thinkpad T450s Fan Replacement
Wat je nodig hebt
  1. Lenovo Thinkpad T450s Fan Replacement, Fan: stap 1, afbeelding 1 van 1
    • Flip the laptop over so that the bottom is facing up.
    • Unlock the battery by sliding the keys outwards. When unlocked, push the battery forwards to remove.
  2. Lenovo Thinkpad T450s Fan Replacement: stap 2, afbeelding 1 van 1
    • Unscrew all 3.7 mm Phillips #0 screws from the back of the laptop. Half of them will remain attached to the cover.
    • Lift off the back cover.
  3. Lenovo Thinkpad T450s Fan Replacement: stap 3, afbeelding 1 van 1
    • Unscrew the four 5 mm Phillips #0 screws that secure the heatsink.
    • The screws will remain attached.
    • The Fan is attached to the heat sink assembly.
  4. Lenovo Thinkpad T450s Fan Replacement: stap 4, afbeelding 1 van 1
    • Use a plastic opening tool or a nylon spudger to push the fan's bundled cable connector free.
    • Remove the fan and heat sink assembly from the motherboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Murphy Derwent
130 Reputatie
1 Handleiding geschreven
IUPUI, Team 2-3, Harley Spring 2022 Lid van IUPUI, Team 2-3, Harley Spring 2022
IUPUI-HARLEY-S22S2G3
3 Leden
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 27
Altijd: 1,326
