Ga door naar hoofdinhoud
Lenovo Thinkpad T450s Bottom Panel Removal
Wat je nodig hebt
  1. Lenovo Thinkpad T450s Bottom Panel Removal, Battery: stap 1, afbeelding 1 van 2 Lenovo Thinkpad T450s Bottom Panel Removal, Battery: stap 1, afbeelding 2 van 2
    • Turn off device before starting
    • Flip the laptop upside down so you have access to the battery.
  2. Lenovo Thinkpad T450s Bottom Panel Removal: stap 2, afbeelding 1 van 1
    • Slide lock button 1 to the unlock position and gently slide away from your body.
  3. Lenovo Thinkpad T450s Bottom Panel Removal: stap 3, afbeelding 1 van 2 Lenovo Thinkpad T450s Bottom Panel Removal: stap 3, afbeelding 2 van 2
    • Slide lock button 2 to the unlock position and continue gently sliding until the battery is removed.
  4. Lenovo Thinkpad T450s Bottom Panel Removal, Lenovo Thinkpad T450s Bottom Panel Removal: stap 4, afbeelding 1 van 3 Lenovo Thinkpad T450s Bottom Panel Removal, Lenovo Thinkpad T450s Bottom Panel Removal: stap 4, afbeelding 2 van 3 Lenovo Thinkpad T450s Bottom Panel Removal, Lenovo Thinkpad T450s Bottom Panel Removal: stap 4, afbeelding 3 van 3
    • Flip the device over and lay it down with the underside facing upwards.
    • Unscrew all 8 screws. While they should not come out completely, in some cases, the plastic retaining washers may come off of one or more of the screws, allowing them to come out completely. - should this happen, look for a loose, tiny black plastic washer once the case is open. It's possible, in some cases, to reattach the retaining washer.
  5. Lenovo Thinkpad T450s Bottom Panel Removal: stap 5, afbeelding 1 van 2 Lenovo Thinkpad T450s Bottom Panel Removal: stap 5, afbeelding 2 van 2
    • Pry the bottom from the computer until it pops out.
    • In some cases, the vented side of the case may cling to the heat sink; appears to be adhesive. Take care when separating.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 28
Altijd: 3,751
