Ga door naar hoofdinhoud
Onderdelen
Geen onderdelen opgegeven.
  1. Make sure to power down and turn off your device before proceeding with the repair. Flip your laptop over so that the backside is facing you.
    • Make sure to power down and turn off your device before proceeding with the repair.
    • Flip your laptop over so that the backside is facing you.
  2. Using a Phillips #1 screwdriver, remove the eight screws securing the backplate.
    • Using a Phillips #1 screwdriver, remove the eight screws securing the backplate.
  3. Using the metal spudger, wedge it in the seam where the backplate meets the front plate and run the tool along the seam to separate the backplate. Using the metal spudger, wedge it in the seam where the backplate meets the front plate and run the tool along the seam to separate the backplate.
    • Using the metal spudger, wedge it in the seam where the backplate meets the front plate and run the tool along the seam to separate the backplate.
  4. Remove the back panel from the device.
    • Remove the back panel from the device.
  5. Use the Phillips #1 screwdriver to remove the four screws securing the fan to gain access to the processor. Use the Phillips #1 screwdriver to remove the four screws securing the fan to gain access to the processor.
    • Use the Phillips #1 screwdriver to remove the four screws securing the fan to gain access to the processor.
  6. Lift the fan assembly to gain access to the thermal paste, from here the thermal paste can be wiped away and replaced. Lift the fan assembly to gain access to the thermal paste, from here the thermal paste can be wiped away and replaced.
    • Lift the fan assembly to gain access to the thermal paste, from here the thermal paste can be wiped away and replaced.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Terelle Montalvo
1.117 Reputatie
8 handleidingen geschreven
UMass Dartmouth, Team S1-G5, Simcock Fall 2018 Lid van UMass Dartmouth, Team S1-G5, Simcock Fall 2018
UMASSD-SIMCOCK-F18S1G5
3 Leden
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 5
Afgelopen 30 Dagen: 46
Altijd: 379
