Ga door naar hoofdinhoud
Lenovo Thinkpad T440s RAM Replacement
Wat je nodig hebt
  1. Lenovo Thinkpad T440s RAM Replacement, Back Panel: stap 1, afbeelding 1 van 2 Lenovo Thinkpad T440s RAM Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Make sure to power down and turn off your device before proceeding with the repair.
    • Flip your laptop over so that the backside is facing you.
  2. Lenovo Thinkpad T440s RAM Replacement: stap 2, afbeelding 1 van 1
    • Using a Phillips #1 screwdriver, remove the eight screws securing the backplate.
    • Don’t try to force screws which won't come out. They are held in place by a stopper on the reverse side. This will not prevent you from removing the backplate.
  3. Lenovo Thinkpad T440s RAM Replacement: stap 3, afbeelding 1 van 2 Lenovo Thinkpad T440s RAM Replacement: stap 3, afbeelding 2 van 2
    • Using the metal spudger, wedge it in the seam where the backplate meets the front plate and run the tool along the seam to separate the backplate.
  4. Lenovo Thinkpad T440s RAM Replacement: stap 4, afbeelding 1 van 1
    • Remove the back panel from the device.
  5. Lenovo Thinkpad T440s RAM Replacement, RAM: stap 5, afbeelding 1 van 2 Lenovo Thinkpad T440s RAM Replacement, RAM: stap 5, afbeelding 2 van 2
    • Right below the battery slot on the right half of the device is where you can access the RAM card Slot.
    • Remove the RAM by pulling it straight out of the device.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Terelle Montalvo
1.477 Reputatie
8 handleidingen geschreven
UMass Dartmouth, Team S1-G5, Simcock Fall 2018 Lid van UMass Dartmouth, Team S1-G5, Simcock Fall 2018
UMASSD-SIMCOCK-F18S1G5
3 Leden
Één opmerking
I have a T460, very similar. A few points missing here… It’s imperative to take out the battery first. Most other tutorials mention disabling the internal battery in the BIOS before starting the process. Then screws don’t come out, they stay attached, which is very nice but better if you expect it. And one of them is right under the battery. The 460 has 2 memory slots, and they’re both functional. I had to swap my 4G card to the second slot, and put the 8G one in to replace it, I don’t know whether that’s mandatory or it was just bad seating initially.
George Mahe - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 44
Altijd: 3,868
