Ga door naar hoofdinhoud
Lenovo Thinkpad T440s Hard Drive Replacement
Wat je nodig hebt
  1. Lenovo Thinkpad T440s Hard Drive Replacement, Back Panel: stap 1, afbeelding 1 van 2 Lenovo Thinkpad T440s Hard Drive Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Make sure to power down and turn off your device before proceeding with the repair.
    • Flip your laptop over so that the backside is facing you.
  2. Lenovo Thinkpad T440s Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • Using a Phillips #1 screwdriver, remove the eight screws securing the backplate.
    • Don’t try to force screws which won't come out. They are held in place by a stopper on the reverse side. This will not prevent you from removing the backplate.
  3. Lenovo Thinkpad T440s Hard Drive Replacement: stap 3, afbeelding 1 van 2 Lenovo Thinkpad T440s Hard Drive Replacement: stap 3, afbeelding 2 van 2
    • Using the metal spudger, wedge it in the seam where the backplate meets the front plate and run the tool along the seam to separate the backplate.
  4. Lenovo Thinkpad T440s Hard Drive Replacement: stap 4, afbeelding 1 van 1
    • Remove the back panel from the device.
  5. Lenovo Thinkpad T440s Hard Drive Replacement, Hard Drive: stap 5, afbeelding 1 van 2 Lenovo Thinkpad T440s Hard Drive Replacement, Hard Drive: stap 5, afbeelding 2 van 2
    • Use the Phillips #1 screwdriver to remove the single screw securing the hard drive.
  6. Lenovo Thinkpad T440s Hard Drive Replacement: stap 6, afbeelding 1 van 1
    • Use the metal spudger to lift the hard drive out of it's compartment.
  7. Lenovo Thinkpad T440s Hard Drive Replacement: stap 7, afbeelding 1 van 2 Lenovo Thinkpad T440s Hard Drive Replacement: stap 7, afbeelding 2 van 2
    • Grab a hold of the hard drive and pull it straight out from the device.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Terelle Montalvo
1.477 Reputatie
8 handleidingen geschreven
UMass Dartmouth, Team S1-G5, Simcock Fall 2018 Lid van UMass Dartmouth, Team S1-G5, Simcock Fall 2018
UMASSD-SIMCOCK-F18S1G5
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 60
Altijd: 9,245
