Inleiding
The possible screens for this model of the T440s are the
- AUO display B140HAN01.2 (FRU: 04X0436)
- LG display LP140WF1 (sp)(k1) (FRU: 04X0626)
I had a AUO installed and replaced, so no judgement on the quality of the LG display, which can be followed in various Thinkpad forums.
Wat je nodig hebt
While booting, press the F1 button to enter the BIOS.
Go to "Config" and then to "Power".
Select "Disable Built-in Battery" and press Enter.
You will be asked to proceed. Select "Yes".
The laptop shuts down.Unplug the laptop from AC.
Remove the battery.
Start removing the front bezel in the lower display corners using a prying tool.
Carefully release the display, turn it around and place it on the keyboard.
Remove the connector together with the label.
When you remove the back cover, it is important that the adhesive tape remains on the cover, not on the old display. In case your adhesive does not work anymore, you should clean the back panel properly and install new adhesive
18 andere personen hebben deze handleiding voltooid.
7 opmerkingen
What about T440s with touch panel?
I do not possess a touch device, sorry.
Can this be done as an upgrade
You mean from “normal” to touch display? I cannot comment on a touch device…
Thanks for the manual. Just fixed my display and changed to an IPS from a T450s.
I just wanted to add to this manual that I replaced the double sided adhesive from the Display bezel with 3 mm double side adhesive (3M 9448A).
I did not get the Bezel off properly with the old adhesive. 3 meters of the tape were sufficient.
