Inleiding
The keyboard is a key component to any computer. It is the place where you mix the electronics and the inputs from typing. It is the place where you tell the computer what to do. This guide will show you how to remove the Lenovo Thinkpad T430 keyboard to be able to replace it.
Wat je nodig hebt
Place the laptop so that the bottom is facing up.
Slide the battery unlock lever to the right.
Gently pull the battery outwards from the body of the device.
Remove the two screws that hold the RAM door in place using a Phillips #000 screwdriver.
Remove the back panel.
Één andere persoon heeft deze handleiding voltooid.
