Wat je nodig hebt
Flip your laptop over.
Unplug all cables from the computer. If you're just swapping the battery, you can leave the power cord plugged in.
Pull the locking tab on the battery towards the unlock position.
Pull the battery out of the socket.
Loosen the following five screws:
5 Phillips #0 screws
1 recessed Phillips #0 screw
Slide the hard drive caddy to your left side using the pull tab.
Once it has been disconnected, pull up on the hard drive.
Reinstall Windows or Linux on the new drive.
