Ga door naar hoofdinhoud
Lenovo Thinkpad Edge E40 Bottom Cover Replacement
Wat je nodig hebt
  1. Lenovo Thinkpad Edge E40 Bottom Cover Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip your laptop over.
    • Unplug all cables from the computer. If you're just swapping the battery, you can leave the power cord plugged in.
  2. Lenovo Thinkpad Edge E40 Bottom Cover Replacement, Battery: stap 2, afbeelding 1 van 1
    • Pull the locking tab on the battery towards the unlock position.
    • Pull the battery out of the socket.
  3. Lenovo Thinkpad Edge E40 Bottom Cover Replacement, Bottom Cover: stap 3, afbeelding 1 van 1
    • Loosen the following five screws:
    • 5 Phillips #0 screws
    • 1 recessed Phillips #0 screw
    • These screws do not come out all the way, and need to be un-tightened a lot more than you might think.
  4. Lenovo Thinkpad Edge E40 Bottom Cover Replacement, Bottom Cover: stap 4, afbeelding 1 van 1
    • Pull up on the front cover from the left and right sides.
    • Do not force the cover off the laptop. If it does not want to come out, undo the screws a bit more.
Conclusie
DistroHopper39B
406 Reputatie
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 62
