Ga door naar hoofdinhoud
Lenovo Thinkpad E540 WiFi Card Replacement
Wat je nodig hebt
  1. Lenovo Thinkpad E540 WiFi Card Replacement, Battery: stap 1, afbeelding 1 van 2 Lenovo Thinkpad E540 WiFi Card Replacement, Battery: stap 1, afbeelding 2 van 2
    • Push the battery release switches away from each other.
  2. Lenovo Thinkpad E540 WiFi Card Replacement: stap 2, afbeelding 1 van 1
    • Remove the battery.
  3. Lenovo Thinkpad E540 WiFi Card Replacement, WiFi Card: stap 3, afbeelding 1 van 1
    • Remove the single 1mm Phillips #0 screw holding the small plastic panel in place.
    For me a Phillips #1 was the first bit with a tight fit (testet PH #00, #0, #1).
    Till - Antwoord
  4. Lenovo Thinkpad E540 WiFi Card Replacement: stap 4, afbeelding 1 van 1
    • Use a plastic opening tool to remove panel.
  5. Lenovo Thinkpad E540 WiFi Card Replacement: stap 5, afbeelding 1 van 2 Lenovo Thinkpad E540 WiFi Card Replacement: stap 5, afbeelding 2 van 2
    • Disconnect the two antenna cables from the wifi card.
    • Remove the single 1mm Phillips #0 screw from the wifi card.
  6. Lenovo Thinkpad E540 WiFi Card Replacement: stap 6, afbeelding 1 van 1
    • Remove the wifi card by sliding it out.
Conclusie
Timothy Sumner
1.040 Reputatie
8 handleidingen geschreven
USF Tampa, Team S2-G5, Nance Spring 2018 Lid van USF Tampa, Team S2-G5, Nance Spring 2018
USFT-NANCE-S18S2G5
4 Leden
2 opmerkingen
Pictures show battery is still connected to laptop.
Monte Christo - Antwoord
There appear to be several different wifi cards available, with different PN numbers. Is it necessary to replace with the exact same PN number? Can these wifi cards be upgraded?
Thomas - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 16
Altijd: 2,916
