Ga door naar hoofdinhoud
Lenovo ThinkPad x120e Hard Drive Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad x120e Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 2 Lenovo ThinkPad x120e Hard Drive Replacement, Battery: stap 1, afbeelding 2 van 2
    • Flip the laptop upside down and locate the battery latches under the battery.
    • Place your thumbs on both latches and push the latch inwards.
    • With your thumbs still on the latches, slide the battery out of the laptop.
    • To install a new battery, simply slide the battery back in the slot. Then, check if both battery latches are locked
  2. Lenovo ThinkPad x120e Hard Drive Replacement, Back Cover: stap 2, afbeelding 1 van 3 Lenovo ThinkPad x120e Hard Drive Replacement, Back Cover: stap 2, afbeelding 2 van 3 Lenovo ThinkPad x120e Hard Drive Replacement, Back Cover: stap 2, afbeelding 3 van 3
    • Using the Phillips #0 screwdriver, remove the three 4 mm screws that are securing the bottom cover.
    • Remove the backplate carefully, making sure not to bend the cover.
  3. Lenovo ThinkPad x120e Hard Drive Replacement, Hard Drive: stap 3, afbeelding 1 van 2 Lenovo ThinkPad x120e Hard Drive Replacement, Hard Drive: stap 3, afbeelding 2 van 2
    • Under the back cover, you'll find the drive bay containing the hard drive on the top left.
    • Using the Phillips #0 screwdriver, remove two 4 mm screws which are located on the top left and bottom right corners.
    • Slide out the hard drive from the back cover horrizontally.
    • The pictures only show the mount, not the actual hard drive. Unfortunately, the hard drive was lost during replacement.
  4. Lenovo ThinkPad x120e Hard Drive Replacement: stap 4, afbeelding 1 van 2 Lenovo ThinkPad x120e Hard Drive Replacement: stap 4, afbeelding 2 van 2
    • Using the same Phillips #0 screwdriver, remove the four 4 mm screws located on each side of the drive bay.
    • Remove the physical hard drive from the drive bay.
Conclusie
Jacob Fronzaglia
787 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team 3-4, Sinclaire Fall 2021 Lid van UMass Dartmouth, Team 3-4, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G4
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 19
Altijd: 250
